Zum Hauptinhalt wechseln
Das Mixed-Reality-Headset Meta Quest 3 wurde am 10. Oktober 2023 veröffentlicht. Es ist der direkte Nachfolger der Meta Quest 2 und in vielerlei Hinsicht der geistige Nachfolger der Meta Quest Pro.
Meta Quest 3 Touch Plus right controller not receiving power from batt
The right controller of my Meta Quest 3 Touch Plus is not receiving any power from the battery. I have already tried standard troubleshooting steps (replacing batteries, checking orientation, checking battery contacts, restarting/re-pairing via Meta app), but there is no LED activity at all. The battery contacts look fine, but power isn't reaching the internals. Has anyone experienced this or knows how to troubleshoot/repair it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Tried reviewing questions already asked and then the Guides section? After exhausting all diy steps from here, Meta Quest 3 forums, if any, try Meta Quest's tech support. Was this dropped at any time (creating internal damage)?
von Teilen
Yes, I also heard from the meta support and after all the attempts, which I had already made by relying on the meta site, then redone with the chat assistance they told me that the only solution was to replace it
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Meta may be what Apple attempted some years ago; block diyers from attempting to replace dead/dying rechargeable batteries in iPods until an entrepreneur posted a diy repair method. At the time, Apple stated their products are not repairable and simply stated that once an iPod fails and is out of warranty (battery death), iPod replacement is recommended. The uproar of iPod owners reading Apple's official response and the diyer posting battery replacement changed Apple's policies. This may have occurred when the right to repair discussions began in many areas; automobiles, farm tractors, electronics, etc.
Meta, a multibillion dollar company may control marketing with their forums. If Meta cannot service VR units in or out of warranty, Meta forums may not be helpful. Third party VR forums may help. Electronics shrunk for weight savings brings repair issues that may be cut and dried; failure = replacement as repairs are too labor intensive/not worth repairing. A disposable economy.
War diese Antwort hilfreich?
Bewertung 1
Since you’ve ruled out the battery and contacts, I’d suspect the battery contact assembly, its connection to the main board, or a fault in the power circuitry.
If you’re comfortable opening it, check for a loose connector, damaged flex cable, or corrosion and measure whether the battery voltage is actually reaching the board. If voltage reaches the board but there’s still no response, the board itself is likely the problem.
Bewertung -1
Antwort hinzufügen
KratosCT wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 47
Insgesamt: 94
