Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für Autos, LKWs und SUVs von GMC.
No oil pressure shut off engine warning
I have a 2011 GMC Acadia Denali 3.6 L AWD
Last Night, when I went to go to work, I got about a mile from my house and I had all kinds of Alarm bells going off and when I looked at my Dash, it said NO OIL PRESSURE, STOP ENGINE NOW, no other warning lights were on
I turned around drove home the mile because I live out in Middle of nowhere, had no phone service, so I couldn't even called for help,
l got my into driveway parkwd car then my husband and son took a look at my car, It has No visible Oil Leaking from Anywhere, oil was right where it was supposed to be on the lipstick, they waited for it to cool down and checked it again, and the oil level was fine.
I had just had a brand new oil change and new filter not even a month ago, and I think I've put Maybe 750-800 miles on it since the oil change.
I have the oil changed with the GMC recommended fully synthetic 5W-30 oil and a High Quality Flter, every 3,000- 3,500 miles. My car has got just over 142,500 miles on it .
What would cause this to happen with no previous warning notification, no other dash lights on to signal an issue, and nothing prior to this.. Other than had to replace the water pump end of July. End Of August we did a Drain/Fill (not flush) with the transmission fluid.
Last summer I had the ignition coils and plugs changed as well as the AC actuators replaced across the dashboard.All Cabin filter replaces, had strut shocks inner tie rods and new tires put on along with an all-wheel drive alignment
Now This summer, other than what I have already listed above... I had a brand new starter put in and a brand new air conditioning compresser line because it cracked. And outer tie rods replaced on the front end and a new front end alignment
Any suggestions or assistance you could give me with regard to the no oil pressure shut engine off notification and alarm Bells coming on, would be greatly appreciated.
Because I honestly cannot afford another trip to the mechanic as I just dropped almost $3,000 in repairs on it back the end of June beginning of July, as well as the $2,375 last summer.
Thank You.
MSPANDA1969
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Some vehicles have two oil monitors; oil pressure and oil level. Oil pressure is standardized whether using actual pressure gage from the Neanderthal age to electronic sensors universally used everywhere. 9 out of 10 times, the oil pressure sensor fails but to be absolutely sure, removal and installing an oil pressure gage and starting the engine will show actual pressures. Oil pressure sensor replacement is a diy procedure for anyone able to change oil. Most sensors have a single wire connection. The oil level sensor may considered an annoyance unless used as a reminder to check oil level for topping up.
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @jeaninersm76908
Check if the Engine Oil Pressure (EOP) switch harness cable is still securely connected to the switch.
The switch is located next to the oil filter for the engine. (see Call Out #6 in diagram)
Also check if the sensor itself is OK i.e. not showing signs of leakage etc. Here's an article that shows what to look for and also what else could be the problem if it is OK.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jeanine R Smith-Grunden wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 47
