Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
428 Fragen Alle anzeigen
Where do I clean if I got finger oil on my parts?
I had my iPhone into a shop for repairing when my power button failed. After I got it back, I have very bad bluetooth reception and almost non-existent WiFi. I remember that the shop did not use gloves. I took it back there and they are denying all responsibility.
So I assume that there's probably some finger oil on various parts and I've seen all of the suggestions on here about cleaning "all contacts" with a degreaser or Windex. But I don't know what "all contacts" are. Can someone help me out and point them out?
Ist dies eine gute Frage?
Bewertung 1
Kommentare:
Any help?
von
Thanks, Brett. I didn't check this until after I left work so I will try on Monday when I have access to my Pentalobe screwdriver.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hey Snowdog,
This is a pretty common problem, and you're correct about the finger oil causing bluetooth to fail.
There are a couple places that you should clean the contacts before re-assembly. While many of connectors in the iPhone use plug-and-socket connections, many just use spring pressure contacts. These pressure contacts are those which you should clean off. Here are a few:
Use some isopropyl alcohol or some Windex on a Q-tip or microfiber cloth, and you should be golden.
Good luck, and let us know how it turns out.
iPhone 4 Einschalttaste und Sperrtaste Bild
Anleitung
iPhone 4 Einschalttaste und Sperrtaste austauschen
Schwierigkeitsgrad:
Schwierig
15 - 30 minutes
iPhone 4 Verizon Power Button Bild
Anleitung
iPhone 4 Verizon Power Button Replacement
Schwierigkeitsgrad:
Schwierig
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
snowdog850 wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 1,569
