1 Diagramm
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Dokumente
Modelle
MM850
Background
The Black & Decker MM850 is a corded electric lawn mower that was first introduced in 2020. It is designed for cutting grass in small to medium-sized residential lawns. The mower is equipped with a 12 amp motor and a 20-inch wide cutting deck made of steel. The height of the cut can be adjusted between 1.25 and 3.75 inches using a centralized lever, which offers seven pre-set positions.
In terms of functionality, the MM850 is designed to keep the power cord out of the way while in use via cord management clips. The handle of the mower can be folded for more compact storage. The mower's relatively light weight of 66 pounds makes it relatively easy to maneuver. It is designed for use on lawns up to a quarter of an acre in size and requires an outdoor power outlet to operate. A grass collection bag can be attached to the rear of the mower to collect clippings, and a mulching plug can be inserted when the bag is removed. Note that the mower is not self-propelled and needs to be pushed in order to operate.
Technical Specifications
- Model Number: BEMW482BH
- Product Type: Corded Electric Mower
- Manufacturer: Black & Decker
- Product Dimensions: 32.5 x 24.8 x 13.1 inches
- Item Weight: 40.9 pounds
- Department: Unisex Adult
- Power Source: Electric corded
- Motor: 12 amp electric
- Cutting Width: 20 inches
- Cutting Height Adjustment: Central 7-position height adjustment from 1.25 to 3.75 inches
- Deck Material: Steel
- Handle: Folding
- Weight: 66 lbs.
Warranty
The Black & Decker MM850 Corded Electric Mower comes with a 3-year limited warranty from the original date of purchase. It covers any defects in materials or workmanship. However, the warranty is not transferable and does not cover normal wear parts like blades and belts beyond 30 days from the date of purchase. In order to make a warranty claim, it is necessary to show proof of purchase.
