2 Diagramme
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Modelle
D55141
Background
The Dewalt D55141 is an air compressor that is made by the Dewalt corporation. It is portable and can be used for light professional and do-it-yourself (DIY) home use. The air compressor is gas-powered and has a noise level of 79 dB. The weight of the compressor is 35.7 lbs and its dimensions are 21.25 x 19 x 10.5 inches. The motor has a capacity of 0.5 horsepower.
The air compressor has a tank capacity of 2 gallons, and can deliver a maximum pressure of 150 PSI, and air delivery of 2.6 SCFM at 90 PSI. It uses an oil-free single stage pump. The air compressor is designed for light duty applications, including the use of nail guns, airbrushes, and other pneumatic tools. Despite its weight, it is designed to be easily portable, with a roll cage and integrated handle. It also has an electric start feature for quick startups. The noise level is moderate, making it suitable for use in garages and small shops.
Technical Specifications
- Power source: Gas-powered
- Noise level: 79 dB
- Weight: 35.7 lbs
- Dimensions: 21.25 x 19 x 10.5 inches
- Motor: 0.5 horsepower
- Tank capacity: 2 gallons
- Max pressure: 150 PSI
- Air delivery: 2.6 SCFM @ 90 PSI
- Pump: Oil-free single stage
Warranty
The Dewalt D55141 Air Compressor comes with a 1-year limited warranty. This warranty specifically covers any defects that may arise due to materials or workmanship used in the manufacturing process. Notably, the warranty also entitles the owner to 1 year of free service. To claim the warranty, customers typically need to reach out to Dewalt's customer service with proof of purchase and a detailed explanation or evidence of the defect or issue encountered. It's also noteworthy to keep the product in its original condition without any unauthorized modifications to ensure that the warranty claim is not voided.
