1 Diagramm
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Modelle
92160120210
Background and Identification
The Diamabrush Coating Removal Tool and Riser (part number 92160120210) is a 16-inch diameter coating removal disk manufactured by Malish. It uses a 25-grit diamond abrasive material to remove adhesives, glue, thin-set epoxies, and thin-mil epoxies like paint or urethane. The disk prevents the diamond abrasive from clogging or shifting to ensure consistent material removal. This coating removal disk is designed for use with automatic scrubbers and flooring machines. It comes assembled with an NP9200 Clutch Plate and 1-1/4-inch Riser so the disk can fit on any 16-inch or 17-inch rotary floor machine.
This model is recommended for wet use, meaning the manufacturer recommends applying water to eliminate dust and flush debris away. It includes ten replaceable diamond blades that can be changed with a replacement kit (only two screws need to be loosened to replace each diamond blade). The disk is meant for machines with a counter-clockwise spin up to 600 revolutions per minute. The diamond blades are designed to work with machines below 115 pounds for a single disk or with less than 115 pounds of pressure. Using this disk with heavier machines may cause damage to the flexible diamond-covered blades.
Technical Specifications
Dimensions:
- Product Height (in.): 4
- Product Length (in.): 16
- Product Width (in.): 16
Details:
- Brand: Diamabrush
- Model: 92160120210
- SKU: 296507
- Abrasive Material: Diamond
- Application: Heavy Duty
- Arbor Size: 16 in.
- Backing Material: Resin
- Grit: 25
- Power Tool Accessory Type: Sanding/Grinding/Polishing Accessory
- Sanding Grade: Coarse
- Sanding, Grinding and Polishing Accessory Type: Diamond Grinding Wheels
- Tools Product Type: Power Tool
- Wheel Diameter (in.): 16"
