18 Diagramme
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Dokumente
Modelle
HCA-2620
Background and Identification
The X Series ECHO model HCA-2620 is a gasoline-powered hedge trimmer. It includes a 21-inch double-sided, double-articulating razor-edge blade on a 59-inch shaft. The trimmer’s head articulates 135 degrees total at 15-degree increments to allow the user to operate it at a variety of cutting angles. The HCA-2620 model can be used at ten different operating positions.
The trimmer includes a 25.4 cc two-stroke gas engine. ECHO recommends using a 50:1 ratio of fuel to oil mix for all two-stroke cycle engines (50:1 ratio is equal to 1 gallon of 89 octane fuel and 2.6 fluid ounces of oil mix). Use a mid-grade to premium gasoline with a minimum octane rating of 89 or higher. The trimmer’s engine produces 1.35-horsepower. The HCA-2620 model includes a 20.6-fluid ounce (about 0.16 liquid gallons) fuel tank.
The hedge trimmer also features a two-stage air filtration system that can be accessed without any tools. It has easy-start capabilities and a cushioned front handle.
The HCA-2620 model can be identified by its orange and black engine cover and handle. The manufacturer’s name, “ECHO,” is printed in black font near the bottom of the shaft and in white font on the side of the engine cover. The trimmer’s fuel tank is a partially-transparent white color.
Technical Specifications
Dimensions:
- Assembled Depth (in.): 96.1 in
- Assembled Height (in.): 10.2 in
- Assembled Width (in.): 10.7 in
- Blade Gap (in.): 1.125
- Blade Length (in.): 21
- Blade Width (in.): 3.125
- Maximum Cut Diameter (in.): 1
- Shaft Length (in.): 59
Details:
- CA (CARB) Compliant: CARB Compliant
- Cut strokes per minute: 5000
- Engine Cycles: 2 Cycle
- Engine Displacement (cc): 25.4
- Engine Type: 2-Stroke
- Features: Antivibration, Articulating Head
- Fuel Tank Capacity (oz.): 20.6
- Included: Shoulder Harness/Strap
- Power Type: Gas
- Product Weight (lb.): 14.3lb
- Shaft Type: Straight
- Single/double-sided blade: Double-sided
- Start Type: Recoil Start
- Trimmer Type: Hand Held
