1 Diagramm
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Dokumente
Modelle
9564CV
Background
The Makita 9564CV is an angle grinder designed for diverse applications such as grinding, cutting, and sanding. This model includes a variable speed control for adjusting the speed according to task requirements. The grinder displays a blue and black color scheme, typical for Makita products. Furthermore, the 9564CV comes with a 13 AMP motor and an electronic limiter to prevent motor overload, ensuring durability and reliable performance. The model number can be found on the label located on the side of the device.
Technical Specifications
- Dimensions: 13 x 5 x 4 inches
- Weight: 5.3 lbs
- Material: Plastic and metal
- Color: Blue and black
- Motor: 13 AMP
- Speed Control: Variable speed (2,800 - 10,500 RPM)
- Electronic Limiter: Yes
- Wheel Diameter: 4-1/2 inches
