Zum Hauptinhalt wechseln
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
Was du brauchst
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 5, Bild 1 von 1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 6, Bild 1 von 1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 7, Bild 1 von 2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 7, Bild 2 von 2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 8, Bild 1 von 1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 9, Bild 1 von 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 9, Bild 2 von 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: Schritt 9, Bild 3 von 3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Abschluss
Tiffany Foo
289 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S19-G4, White Winter 2019 Mitglied von Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 366
