Zum Hauptinhalt wechseln
Acer Aspire R7-572-6423 Battery Replacement
Was du brauchst
  1. Acer Aspire R7-572-6423 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire R7-572-6423 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the top and middle rubber feet under the laptop to reveal hidden screws.
  3. Acer Aspire R7-572-6423 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the five 6 mm T9 screws.
    • Remove the eight 10 mm T9 screws.
  4. Acer Aspire R7-572-6423 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover.
  5. Acer Aspire R7-572-6423 Battery Replacement: Schritt 5, Bild 1 von 1
    • Unplug the ribbon cable connecting the battery to the motherboard.
    • Be careful around the motherboard, as it is easily damaged.
  6. Acer Aspire R7-572-6423 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 4 mm Phillips #1 screws securing the battery.
  7. Acer Aspire R7-572-6423 Battery Replacement: Schritt 7, Bild 1 von 2 Acer Aspire R7-572-6423 Battery Replacement: Schritt 7, Bild 2 von 2
    • Pull open the clips on either side of the battery to free it from the case.
    • Remove the battery from the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 1,514
