Zum Hauptinhalt wechseln
Acer Aspire V5-552PG-X469 Battery Replacement
Was du brauchst
  1. Acer Aspire V5-552PG-X469 Battery Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the storage tray on the left edge of the device.
  2. Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
  3. Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift up the back case to remove it.
  4. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Aspire V5-552PG-X469 Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Pull the battery connector away from the hard drive to disconnect it from its socket.
  5. Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 5, Bild 3 von 3
    • Pull the white connector toward the battery to disconnect it.
    • Pull the black tape-wrapped connector toward the battery to disconnect it.
  6. Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 6, Bild 1 von 2 Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the PH #0 screw from the center of the battery.
  7. Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 7, Bild 1 von 2 Acer Aspire V5-552PG-X469 Battery Replacement: Schritt 7, Bild 2 von 2
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
Abschluss
Rebecca Aseo
304 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 1,246
