Zum Hauptinhalt wechseln
Acer Chromebook C720-2420 Battery Replacement
Was du brauchst
  1. Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2420 Battery Replacement, Back Cover Replacement: Schritt 1, Bild 2 von 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Acer Chromebook C720-2420 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2420 Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
Abschluss
USF Tampa, Team S15-G4, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 551
