Einleitung
The trackpad replacement for the Acer Chromebook C740 requires removing the back panel, removing the battery, unplugging a ribbon cable, and removing several screws.
Was du brauchst
Place the chromebook bottom side up on a flat surface.
Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
Pull the ribbon cable out from the connector.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
