Zum Hauptinhalt wechseln
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
Was du brauchst
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: Schritt 1, Bild 1 von 1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: Schritt 2, Bild 2 von 2
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Tony
459 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 10-5, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
no help i need help putting it on with out that
Simon Kuhn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 99
Insgesamt: 7,259
