Zum Hauptinhalt wechseln
Acer Chromebook CB3-111-C670 WLAN Chip Replacement
Was du brauchst
  1. Acer Chromebook CB3-111-C670 WLAN Chip Replacement, WLAN Chip: Schritt 1, Bild 1 von 1
    • Turn off your Chromebook and disconnect any charging cables.
    • Turn the Chromebook over so that the back panel with the Chromebook's serial number is facing upward.
    • Use the Phillips #000 screwdriver to remove the twelve screws from the back panel.
    • Use an opening tool to detach the back panel. Start at one of the four corners of the Chromebook and gently work around the edges. Insert it in the crease where the back panel and the main board meet. You should hear a slight click; this is the sound of the back panel detaching from the board.
    • Be careful not to apply too much force or you could damage the ribbon cable that connects the back panel to the motherboard.
    • Once you have detached the back panel, do not lift it vertically from the Chromebook. With the Chromebook facing in the direction as shown in the picture above, take the right hand side of the back panel and lift it toward the left, as if you are opening a book.
  2. Acer Chromebook CB3-111-C670 WLAN Chip Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: Schritt 2, Bild 3 von 3
    • Disconnect the coaxial cables from the WLAN board located near the top left corner of the motherboard.
    • Grasp the top and bottom edge of the WLAN board using your fingers and gently disconnect it from the motherboard.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
lott
323 Reputation
1 Anleitung geschrieben
USF Tampa, Team 10-5, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 1,756
