Zum Hauptinhalt wechseln
Acer Chromebook R11 C738T-C44Z Motherboard Replacement
Was du brauchst
  1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: Schritt 2, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: Schritt 2, Bild 2 von 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: Schritt 5, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: Schritt 5, Bild 2 von 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  6. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  7. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully slide the wireless card out of its socket from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Disconnect the LED board ribbon by pulling it out gently.
    • Disconnect the speaker cable.
  9. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the keyboard ribbon.
    • Slide it out gently to not rip it.
  10. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 10, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
  11. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 11, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the touchpad ribbon by lifting up the tab and pulling it out.
  12. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 12, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the sensor cable by pulling it out.
  13. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 13, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 13, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Disconnect the LCD cable by pinching it and lifting it off the motherboard.
  14. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 14, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
  15. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 15, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 15, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
  16. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 16, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Slide the opening tool underneath the hinge latch to lift it up.
    • This is to free the motherboard.
  17. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 17, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Grab the motherboard securely to lift and remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gateway, Team 1-4, Saknee Fall 2021 Mitglied von Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 16
Insgesamt: 455
