Einleitung
Use this guide to replace the fan in the Acer Nitro 5 AN515-53-52FA, before using this guide open up the computer and use a can of air on the fan.
The fan is the cooling unit of the laptop, without the fans the laptop would not cool and overheat. A broken fan can make uncommon noises, and ruin the performance of the laptop. Dirt or dust could get lodged into the fan forcing them to stop and overheat the laptop.
The Old fans of the laptop can easily be recycled after.
Was du brauchst
Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
Use a plastic opening pick to work your way around the edges to remove the bottom case carefully.
Removing the backshell of the laptop will reveal the inside of it.
Use the Phillips #0 screwdriver to remove the four 9 mm screws securing the fans.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
