Zum Hauptinhalt wechseln
Acer Predator 17 G9-793 Battery Replacement
Was du brauchst
  1. Acer Predator 17 G9-793 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to unscrew the two captive screws on the service panel cover.
    • Captive screws are meant to stay in place, so you only need to loosen them to remove the panel.
    • Use a spudger or opening tool to remove the service panel.
  2. Acer Predator 17 G9-793 Battery Replacement: Schritt 2, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 2, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 2, Bild 3 von 3
    • Detach the hard drive connector with a gentle upward pull of the attached pull tab.
    • Remove the hard drive from its slot.
  3. Acer Predator 17 G9-793 Battery Replacement: Schritt 3, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 3, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the single 4 mm Phillips #0 screw.
    • The SSD card will lift slightly.
    • Carefully slide the SSD card away from the socket.
  4. Acer Predator 17 G9-793 Battery Replacement: Schritt 4, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 4, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 4, Bild 3 von 3
    • Firmly pull the switch into the open position.
    • The removable drive will pop out slightly.
    • Slide the drive out of its slot.
  5. Acer Predator 17 G9-793 Battery Replacement: Schritt 5, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 5, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove:
    • six 8 mm screws
    • four 14 mm screws
    • ten 4.5 mm screws
  6. Acer Predator 17 G9-793 Battery Replacement: Schritt 6, Bild 1 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 6, Bild 2 von 3 Acer Predator 17 G9-793 Battery Replacement: Schritt 6, Bild 3 von 3
    • Use an opening tool to remove the back panel.
    • Work your way around the edge of the device to undo the clips and avoid breaking the back case.
  7. Acer Predator 17 G9-793 Battery Replacement: Schritt 7, Bild 1 von 2 Acer Predator 17 G9-793 Battery Replacement: Schritt 7, Bild 2 von 2
    • Unplug the battery connector from the motherboard. Pull the cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • This cable is wide and comes out easily. If it gives you too much resistance, reset your grip and make sure you are pulling straight out of the socket.
  8. Acer Predator 17 G9-793 Battery Replacement: Schritt 8, Bild 1 von 2 Acer Predator 17 G9-793 Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the six 4 mm Phillips #0 screws from the perimeter of the battery.
    • Lift the battery out of the device.
    • Now replace your old battery with a new one!
Abschluss
Timothy Cooper
157 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-4, Watkins Fall 2023 Mitglied von Austin Community College, Team 1-4, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 197
