Einleitung
If the Astro A20 will not turn on or the battery will not charge then you will need to replace the battery.
Was du brauchst
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
