Zum Hauptinhalt wechseln
Asus Chromebook C300M Battery Replacement
Was du brauchst
  1. Asus Chromebook C300M Battery Replacement, Bottom Panel: Schritt 1, Bild 1 von 1
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Battery Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C300M Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Battery Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Battery Replacement: Schritt 4, Bild 1 von 1
    • Open the Chromebook at hinges.
  5. Asus Chromebook C300M Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the 6.0mm Philips screws from around the battery. Make sure to disconnect the battery from the motherboard.
  6. Asus Chromebook C300M Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the laptop.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Tampa, Team 1-1, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-1, Whiteside Fall 2015
UT-WHITESIDE-F15S1G1
3 Mitglieder
8 Anleitungen geschrieben
11 Kommentare
It's not clear from these instructions how to actually disconnect the battery's wires from the main board... can you provide some guidance there?
Mike Kelly - Antwort
PLS ANSWER MIKES QUESTION. You cant just remove the battery without disconnecting a wire which seems fragile so I can not go any further without this instruction. sighhhhhhdsgkhdsf;gklfxgbl;dfkbn; so annoying.
Aaron Simich - Antwort
I replaced the battery, no problem Thank you Jake Van Loon and 4 others. My current problem is - in the process of replacing the battery the thin white strip that comes down from the top became disconnected. I notice in Step 4 of the Battery instructions that the strip is attached but in Step 5 is isnt. Can someone explain to me just how to reconnect that. Please. Any help is truely appreciated.
cc manley - Antwort
The battery plug is like no other I have ever seen.
Can / Will anyone comment on how to unplug it?
Thanks in advance
kaulad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 92
Insgesamt: 22,083
