Zum Hauptinhalt wechseln
Asus Chromebook C300MA-DB01 Battery Replacement
Was du brauchst
  1. Asus Chromebook C300MA-DB01 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 6, Bild 1 von 1
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Battery Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out of the laptop
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
wyatt boyatt
541 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S4-G3, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 2,247
