Einleitung
Use this guide to replace the screen of the Replace the screen on your Asus Eee PC 1005HA laptop.
Was du brauchst
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
Using tweezers, remove the six screw covers on the screen bezel.
Remove the six 4.6 mm screws from the bezel.
Use a plastic opening tool to disengage the plastic clips that secure the screen bezel to the display.
Carefully remove the bezel from the display.
Remove the four 3.6 mm screws securing the screen.
Slowly lift the screen up from the rest of the laptop.
Remove the plastic tape securing the display cables to the back of the screen.
Slide the display cable connector out its socket on the back of the screen.
Remove the four 3.1 mm housing screws on the sides of the display housing frame
Remove the housing frame.
13 weitere Nutzer:innen haben diese Anleitung absolviert.
