Zum Hauptinhalt wechseln
Asus Eee PC 900 RAM Replacement
Was du brauchst
  1. Asus Eee PC 900 RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Asus Eee PC 900 RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Asus Eee PC 900 RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Asus Eee PC 900 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Remove the sticker from the RAM compartment using a pair of tweezers.
  4. Asus Eee PC 900 RAM Replacement: Schritt 4, Bild 1 von 2 Asus Eee PC 900 RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
  5. Asus Eee PC 900 RAM Replacement: Schritt 5, Bild 1 von 1
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
  6. Asus Eee PC 900 RAM Replacement: Schritt 6, Bild 1 von 1
    • Remove the back cover by pulling up on the side that had the screws.
  7. Asus Eee PC 900 RAM Replacement: Schritt 7, Bild 1 von 2 Asus Eee PC 900 RAM Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
  8. Asus Eee PC 900 RAM Replacement: Schritt 8, Bild 1 von 1
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian Carreon
288 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-27, Amido Winter 2012 Mitglied von Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 8,813
