Einleitung
Use this guide to remove the keyboard on the Asus G73JH-RBBX05.
Was du brauchst
Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
In order to remove these cables, push forward the black retention clips and pull out the cables.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
