Zum Hauptinhalt wechseln
Asus Transformer Pad Infinity Charging Port Replacement
Was du brauchst
  1. Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 2 Asus Transformer Pad Infinity Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Take off the screen and the big motherboard.
  2. Asus Transformer Pad Infinity Charging Port Replacement: Schritt 2, Bild 1 von 3 Asus Transformer Pad Infinity Charging Port Replacement: Schritt 2, Bild 2 von 3 Asus Transformer Pad Infinity Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  3. Asus Transformer Pad Infinity Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Flip up the piece securing the ribbon to the big motherboard and remove the ribbon from the motherboard.
    • Note: This will have tape covering it, make sure not to cut the ribbon or scratch any other parts if you are looking to preserve these things.
  4. Asus Transformer Pad Infinity Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the two screws holding the actual port, that goes to the outside of the device, in. This piece will be connected to the case.
  5. Asus Transformer Pad Infinity Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Once removing the damaged charging port, put in your new part and reassemble the device and check if the new charging port works.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Allison Poh
549 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 1,105
