Einleitung
Is your Asus Transformer Pad (TF103C) not charging? Does the battery not last very long? This guide will walk you through the steps of replacing the battery of the Asus Transformer Pad.
Replacing the battery is relatively simple. It only takes 5 steps to complete. Very basic tools are required, but can be switched out for more common tools.
Remember, punctured batteries can cause dangerous fires, so use caution when handling the battery.
Was du brauchst
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Slide the tool in the gap along all four sides, continually pulling the tool upwards.
Remove the back cover once it is loose and set it aside.
Rotate the tablet so it matches the picture.
Carefully unplug the battery cable from the motherboard by grabbing the wires close to the black piece and pulling it out of the housing.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
I had problems with the power button and thanks to your detailed explaination I managed to get the things ok
thanks a lot
Paolo
My tab didn't turn on (stuck in booting limbo), didn't want to wait for a month or so till the battery dropped to 0%, so I tried this method instead. Done everything correctly. I'm sure I didn't screw up. Tablet won't start again (not even charging). I'm not sure if is either the faulty battery or the chipset attached to it. Either way, is a crappy tablet, never happened to lose a device so easily after a DIY repair. This would never happened if only Asus did insert reset buttons on their devices (or a soft reset button sequence). Will never buy an Asus tablet again.
Did you plug the new battery wires correctly
red on red and so on the other?
Hi, i changed the battery, but now I have kind of a situation with this. My brand new battery is losing energy pretty fast , until 2%. When this reach 2% I can use the tablet for more than 10h with the screen on, or more. But if I use it for 2 h , in 2% , an then I close the screen for 5 minutes, the tablet shut down , and I can't open it until I put back the charger. Even though I have plenty of juice in the battery. How do I fix this ? Is there a way to recalibrate the software? I already tried to connect and disconnect the battery and charger back to 100. It doesn't work. I reinstalled the latest version of software. Doesn't work. Can anyone help me ?
I have an Asus Transformer pad. I bought it brand new 2 years ago. I charged the battery andturned it on. It turned on one time. I tried to turn it on a second time and couldn't do it. I sent it back to Asus for repair. They claimed they repaired it. I got it back and tried turning it on after charging battery. Again..went on but wouldn't ever come on again. This unit was obviously never checked out for qualify control. I never used it. Not even once! What a total ripoff! I will Never buy Asus again.
Izzorobert@yahoo.com
