Zum Hauptinhalt wechseln
Asus Transformer T100 Battery Replacement
Was du brauchst
  1. Asus Transformer T100 Battery Replacement, Rear Cover: Schritt 1, Bild 1 von 2 Asus Transformer T100 Battery Replacement, Rear Cover: Schritt 1, Bild 2 von 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Battery Replacement: Schritt 2, Bild 1 von 2 Asus Transformer T100 Battery Replacement: Schritt 2, Bild 2 von 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Battery Replacement: Schritt 3, Bild 1 von 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Battery Replacement: Schritt 4, Bild 1 von 2 Asus Transformer T100 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the rear casing.
  5. Asus Transformer T100 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the copper tape carefully.
  6. Asus Transformer T100 Battery Replacement: Schritt 6, Bild 1 von 2 Asus Transformer T100 Battery Replacement: Schritt 6, Bild 2 von 2
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
  7. Asus Transformer T100 Battery Replacement: Schritt 7, Bild 1 von 3 Asus Transformer T100 Battery Replacement: Schritt 7, Bild 2 von 3 Asus Transformer T100 Battery Replacement: Schritt 7, Bild 3 von 3
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
  8. Asus Transformer T100 Battery Replacement: Schritt 8, Bild 1 von 2 Asus Transformer T100 Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
Abschluss
69 weitere Personen haben diese Anleitung absolviert.
Taylor Pantiga
1.611 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 13-31, Maness Spring 2014 Mitglied von Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Mitglieder
22 Kommentare
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Antwort
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes -
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Antwort
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Antwort
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 23
Letzte 30 Tage: 120
Insgesamt: 130,505
