Einleitung
The motherboard of the device is the tablet's main processing unit. To reach it, the plastic backing, battery, and camera must be removed.
Was du brauchst
Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
Remove the tablet by lifting up.
Insert the opening tool into the seam of the tablet casing and gently pry upwards.
With a little force, you will feel the clips release.
Slide the tool along all four edges of the tablet, making sure that all the clips are released.
The camera board is located in the red square in this image.
Lift up the power button cable retention clip on the motherboard and pull the cable out.
On the camera connection apparatus, locate the silver tape that connects to the tablet.
Peel the silver tape off of the tablet on both sides of the connection apparatus.
Gently pull back the yellow transparent plastic covering on top of the battery connection port.
Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
Remove the battery by slowly peeling the battery away from the connected side.
The adhesive on the back will pull away from the battery.
Locate the twisted black and red wire at the bottom of the motherboard.
Use tweezers to gently slide the black and red wire out of the connection port on the motherboard.
Next to the black and red wire, locate a black wire with a sliver connection ending.
Use tweezers to disconnect that wire from the motherboard
At the top end of the motherboard, use tweezers to gently slide the orange connection apparatus out of the connection port.
Next to the orange connection apparatus port, locate the LCD connection apparatus.
Use tweezers to peel the protective layer off of the connection port.
Once the tape is removed, the LCD connection port should look like this.
Using the tweezers, gently remove the LCD connection apparatus from the LCD connection port.
Using the top end of the motherboard as a hinge and fold the motherboard back so it rests outside of the tablet chassis.
If done correctly, the motherboard should look the picture above.
17 weitere Nutzer:innen haben diese Anleitung absolviert.
11 Kommentare
As the previous comment stated (but only for step 7), ALL the connection apparatus have a white "flip" side (for STEP 7, 9, 17 and 19). Instead of struggling (like I did first), simply lift up the white side with your nail and gently remove the ribbons. Also, it is not necessary to entirely remove the battery (STEP 13) to carefully disconnect the cables. Thanks for for the tutorial though!
Hey! I have the T100TA. Super happy with it, but it's a bit older and only has 1gb of RAM. Is it possible to put the board of the T100(which has 2gb of RAM) into it? I assume size is the same, but are the connections? Thanks!
I have “downgraded” my T100TAM by installing a motherboard from the T100 (because I couldn’t find a T100TAM motherboard). So the other way around should also be possible.
I replaced the motherboard. Did everthing right. But it didn't turned on.
Is there any way to start up the motherboard first time?
Where is the hard drive located on these? Is it on the board and can it be swapped out? I have data on one which is locked and the device won’t boot to anything at all so stuck!
