Zum Hauptinhalt wechseln
Asus VivoBook Q200E-BSI3T08 Battery Replacement
Was du brauchst
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 3, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 5, Bild 1 von 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 5, Bild 2 von 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 5, Bild 3 von 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 6, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: Schritt 6, Bild 2 von 2
    • Now just lift the battery out of place.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Maxim
462 Reputation
1 Anleitung geschrieben
UWT Liner: Group 6 Mitglied von UWT Liner: Group 6
Community
3 Mitglieder
2 Kommentare
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Antwort
Great guide. Thanks!
weston.fisher - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 19
Insgesamt: 7,345
