Zum Hauptinhalt wechseln
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
Was du brauchst
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 3, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 5, Bild 1 von 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 5, Bild 2 von 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 5, Bild 3 von 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 6, Bild 1 von 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 6, Bild 2 von 2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: Schritt 7, Bild 1 von 1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 9, Bild 1 von 1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 11, Bild 1 von 1
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 12, Bild 1 von 1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: Schritt 13, Bild 1 von 1
    • Lift the trackpad up from the laptop and slide it out of the housing.
Abschluss
IUPUI, Team S4-G4, Wilson Summer 2017 Mitglied von IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 570
