Zum Hauptinhalt wechseln
Bose portable speaker battery Replacement
Was du brauchst
    • flip speaker over onto its back
    Frag FixBot
    Kommentar hinzufügen
    • using a heat gun, soften the adhesive holding the ring in place.
    Frag FixBot
    • peel off the ring that covers the screws
    • using your screwdriver, undo the 4 screws that hold the base onto the body of the speaker.
    Frag FixBot
    • using your heat gun, apply a slight amount of heat to soften the adhesive.
    • during reassembly, apply the new adhesive.
    Frag FixBot
    • using your screwdriver, undo the 4 screws holding the speaker assembly in place.
    • carefully pry in the edge of the speaker assembly.
    • be very careful when prying as it is still connected to the motherboard wires.
    Frag FixBot
    • using a spludger, carefully disconnect the speaker cables from the motherboard.
    • be very careful not to damage the connector.
    Frag FixBot
    • using your spludger, carefully pry up the battery.
    • be very careful not to puncture the battery.
    Frag FixBot
    • using 2 fingers, pinch the connector connecting the battery and pull it straight out.
    Frag FixBot
Abschluss
776831
1.067 Reputation
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 30
Insgesamt: 833
