Zum Hauptinhalt wechseln
DJI Mavic Pro Propeller Replacement
Was du brauchst
  1. DJI Mavic Pro Propeller Replacement, Propellers: Schritt 1, Bild 1 von 3 DJI Mavic Pro Propeller Replacement, Propellers: Schritt 1, Bild 2 von 3 DJI Mavic Pro Propeller Replacement, Propellers: Schritt 1, Bild 3 von 3
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: Schritt 2, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 2, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 2, Bild 3 von 3
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: Schritt 3, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 3, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 3, Bild 3 von 3
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: Schritt 4, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 4, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 4, Bild 3 von 3
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: Schritt 5, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 5, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 5, Bild 3 von 3
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: Schritt 6, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 6, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 6, Bild 3 von 3
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: Schritt 7, Bild 1 von 3 DJI Mavic Pro Propeller Replacement: Schritt 7, Bild 2 von 3 DJI Mavic Pro Propeller Replacement: Schritt 7, Bild 3 von 3
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: Schritt 8, Bild 1 von 2 DJI Mavic Pro Propeller Replacement: Schritt 8, Bild 2 von 2
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: Schritt 9, Bild 1 von 2 DJI Mavic Pro Propeller Replacement: Schritt 9, Bild 2 von 2
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team R-28, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-28, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG28
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 98
Insgesamt: 4,251
