Einleitung
Having trouble with broken or stick keys on your keyboard? This guide will provide you simple step-by-step instructions on replacing your keyboard for the Chromebook 13-7310.
Was du brauchst
Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
To remove the battery, lift up on one side to get your fingers underneath and lift away.
Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using your fingernails, pull the cooling fan cables loose from the motherboard.
Finally, lift the fan assembly away from the computer.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I’ve never pulled apart a computer before, and this guide was perfect! thanks
