Zum Hauptinhalt wechseln
Dell Inspiron 15 3593 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 15 3593 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15 3593 Battery Replacement: Schritt 2, Bild 2 von 2
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15 3593 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15 3593 Battery Replacement: Schritt 3, Bild 3 von 3
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15 3593 Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out carefully and put the new battery in.
Abschluss
Reassemble the computer by following
the above steps in reversed order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Abdul Obaid
169 Reputation
1 Anleitung geschrieben
York University, Team R-20, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-20, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG20
1 Mitglied
2 Kommentare
not all of the steps
there is somethings missing
aaaa2020 - Antwort
So where is the rest of the story?
Jeanette Martinez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 98
Insgesamt: 2,650
