Zum Hauptinhalt wechseln
Dell Inspiron 15-3543 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15-3543 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,035
