Zum Hauptinhalt wechseln
Dell Inspiron 15-7537 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-7537 Battery Replacement, Bottom Case: Schritt 1, Bild 1 von 1
    • Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
    • Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
    • These screws will stay captive to the case.
  2. Dell Inspiron 15-7537 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5 mm interior screws that connect the cover to the assembly using the same Philips head screwdriver from the previous step.
  3. Dell Inspiron 15-7537 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to remove the base cover from the rest of bottom cover.
  4. Dell Inspiron 15-7537 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
  5. Dell Inspiron 15-7537 Battery Replacement: Schritt 5, Bild 1 von 1
    • Ground the system board by turning over the computer, opening the display, and holding the power button down for about 5 seconds before proceeding.
    • Using the pull tab on the battery, lift the battery out of the computer.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 18-2, Maness Winter 2015 Mitglied von Cal Poly, Team 18-2, Maness Winter 2015
CPSU-MANESS-W15S18G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 33
Insgesamt: 6,991
