Zum Hauptinhalt wechseln
Dell Inspiron 15-7559 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-7559 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15-7559 Keyboard Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15-7559 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S3-G2, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
How to put it back
Using Name - Antwort
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 41
Insgesamt: 6,858
