Zum Hauptinhalt wechseln
Dell Inspiron 17-5749 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 17-5749 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-5749 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Abschluss
Christopher Tran
1.161 Reputation
12 Anleitungen geschrieben
Washington State, Team S1-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G2
6 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 422
