Zum Hauptinhalt wechseln
Dell Inspiron 3520 Optical Drive Replacement
Was du brauchst
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 3520 Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 3520 Optical Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 3520 Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: Schritt 3, Bild 1 von 2 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 3520 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: Schritt 6, Bild 1 von 2 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: Schritt 6, Bild 2 von 2
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 3520 Optical Drive Replacement: Schritt 7, Bild 2 von 2
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ian
1.557 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-2, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Mitglieder
Ein Kommentar
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 2,492
