Einleitung
This guide will walk you through how remove the battery from the systems board of a Dell Inspiron 7573 2-in-1. This guide is useful for replacing a battery that may be defective or damaged such as if the battery may not be holding a full charge. If your battery isn’t holding charge like it used to, use this guide to replace it!
Was du brauchst
Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
Lift off the bottom cover.
Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
Using the pull tab, disconnect the battery cable from the system board.
Lift the battery out from the laptop case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
