Zum Hauptinhalt wechseln
Dell Inspiron N4010 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron N4010 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron N4010 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N4010 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron N4010 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S13-G5, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 995
