Zum Hauptinhalt wechseln
Dell Latitude 3190 Battery Replacement
Was du brauchst
  1. Dell Latitude 3190 Battery Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Latitude 3190 Battery Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Latitude 3190 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Latitude 3190 Battery Replacement: Schritt 2, Bild 3 von 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Locate the battery.
  4. Dell Latitude 3190 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Latitude 3190 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Latitude 3190 Battery Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Latitude 3190 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Latitude 3190 Battery Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Battery Replacement: Schritt 6, Bild 1 von 3 Dell Latitude 3190 Battery Replacement: Schritt 6, Bild 2 von 3 Dell Latitude 3190 Battery Replacement: Schritt 6, Bild 3 von 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
Abschluss
Daniel Tzunum
214 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-5, Saknee Fall 2021 Mitglied von Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 22
Letzte 30 Tage: 78
Insgesamt: 1,583
