Einleitung
Utilize this step-by-step manual for swapping out the screen on your Dell Latitude 3520 laptop. If you are experiencing frequent screen blackouts or visibility issues, it might be the right moment for a replacement.
Was du brauchst
Push the microSD-card to eject it from the slot.
Remove the microSD-card from the computer.
Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
Carefully lift and remove the base cover.
Remove the 2mm Phillip #0 screw that secures the WLAN card bracket to the WLAN card on the system board.
Lift and remove the WLAN card bracket from the WLAN card that secures the two antenna cables.
Disconnect the antenna cables from the connectors on the WLAN card.
Disconnect and remove the WLAN card from the WLAN card slot.
Peel the adhesive tape, open the latch, and disconnect the I/O cable from the connector on the system board.
Lift and remove the I/O cable from the assembly.
Unroute the display cable from the routing guides in the assembly.
Peel the adhesive tape that secures the display cable in place.
Remove the one 4.55mm Phillip # 0 screw and six 2.5mm Phillip #0 screws that secure the display hinges to the system.
