Zum Hauptinhalt wechseln
Dell Latitude 7420 Battery Replacement
Was du brauchst
  1. Dell Latitude 7420 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude 7420 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Latitude 7420 Battery Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: Schritt 3, Bild 1 von 2 Dell Latitude 7420 Battery Replacement: Schritt 3, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: Schritt 5, Bild 1 von 2 Dell Latitude 7420 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Hong Lee
208 Reputation
1 Anleitung geschrieben
York University, Team S1-G15, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G15, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G15
1 Mitglied
2 Anleitungen geschrieben
Ein Kommentar
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 59
Letzte 30 Tage: 327
Insgesamt: 10,366
