Einleitung
If the keyboard is broken, missing, or malfunctioning you can replace the keyboard of the Dell Precision 5510 in 5 steps by following this guide.
Was du brauchst
Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
Remove the 12 screws that secure the base cover to the computer.
There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Remove all standalone motherboard screws.
8 screws with lengths of either 3.7mm or 4.65mm
