Zum Hauptinhalt wechseln
Dell Studio 1737 Keyboard Replacement
Was du brauchst
  1. Dell Studio 1737 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Studio 1737 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: Schritt 4, Bild 1 von 3 Dell Studio 1737 Keyboard Replacement: Schritt 4, Bild 2 von 3 Dell Studio 1737 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Studio 1737 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Studio 1737 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the ribbon cable as shown
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S8-G4, Catania Spring 2017 Mitglied von UMass Dartmouth, Team S8-G4, Catania Spring 2017
UMASSD-CATANIA-S17S8G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 694
