Einleitung
The battery may either be damaged or have enough capacity to sustain the charge it is holding. These are the necessary steps you can take to replace it.
Was du brauchst
Use a Torx T5 screwdriver to remove the 10 screws from the computer's base plate.
Use a prying tool or a fingernail to lift up and remove the base cover.
Use a Phillips #0 screwdriver to remove all of the screws securing the battery.
Use a spudger to lift the edge of the battery, then carefully remove it.
To reassemble your device, after the new battery has been put in place, screw all 10 screws back on the base cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
