Zum Hauptinhalt wechseln
Dell XPS 15 9570 Fan Replacement
Was du brauchst
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Fan Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Fan Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Fan Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: Schritt 6, Bild 1 von 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: Schritt 7, Bild 1 von 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: Schritt 8, Bild 1 von 2 Dell XPS 15 9570 Fan Replacement, Fan: Schritt 8, Bild 2 von 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: Schritt 9, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: Schritt 10, Bild 1 von 2 Dell XPS 15 9570 Fan Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: Schritt 11, Bild 1 von 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
Abschluss
Clay Caldwell
339 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 2-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 41
Letzte 30 Tage: 184
Insgesamt: 5,087
