Einleitung
If your Dell XPS 17 9710 is not powering on, not staying on when not connected to the charger, or is not holding a charge for very long, you may need to replace the battery.
Before following this guide, first try using a new power cable. The power cable might be dead.
Before beginning, make sure to completely power off the device.
Was du brauchst
Remove eight 5 mm screws from the back panel using a T5 Torx screwdriver.
Use the opening tool to loosen the panel on all sides and then lift it from the device.
Remove seven 3 mm screws securing the battery using a JIS #1 screwdriver.
Use the spudger to detach the battery connector from the motherboard.
Gently unplug this attachment.
Remove the battery from the laptop.
