Zum Hauptinhalt wechseln
Direct-Drive Cleaner Head Brush Bar Replacement
Was du brauchst
  1. Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: Schritt 1, Bild 1 von 2 Direct-Drive Cleaner Head Brush Bar Replacement, Brush Bar: Schritt 1, Bild 2 von 2
    • First, make sure the device is unplugged and detached from the wand
    • Use a quarter to unlock the fastener marked by padlocks, turning it counter clockwise
    • Padlocks
  2. Direct-Drive Cleaner Head Brush Bar Replacement: Schritt 2, Bild 1 von 1
    • Slide the brush bar away from the cleaner head
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G5, Rose Fall 2017 Mitglied von UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Mitglieder
15 Anleitungen geschrieben
2 Kommentare
While a clogged head was not the reason my Dyson V8 was stuttering, logic prompted me to check the big tube for an obstruction. My Dyson had a hairball as a result of picking up after my cat. Thank you!
John McCormick - Antwort
My daughters Dyson V8 head is not powering the tube and rotating head. I have a Dyson V10 animal which I can attach to the V8 tube and rotating head and operates, so the problem is in the power head. I have cleaned the contacts and don’t know what else to do. Any suggestions?
Tom Murphy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 52
Letzte 30 Tage: 224
Insgesamt: 35,318
